08 Ruckus will only start with Kick Starter.
I have replaced Battery with 4 different ones. Replaced all the relays, spark plug and coil.
Any thoughts on what it could be. I have searched the forums for answers as well as google searches and YouTube. Battery is always the answer but 4 batteries would fix it.
I get one click from Relay when I push the start button. Nothing turns over.
Thanks
i would think spark plugs or carb to start.
are your jets clogged?
does it turn over?
just read that you changed the spark plugs. ave you checked fuel delivery? jets n the carb could be clogged
how do your fuses look?
I rebuilt carb 2 times all balls rebuild kit . It will run poorly.
Replaced variator, coil, belt, and fuses
And pulled the cover and cleaned flywheel on stator.
I am lost
