So… After mounting my rear wheel and doing some measurements I have discovered that is off center about a half inch. Come to find out my wheel offset is 2 1/2 by 4 1/2. The only thing I can do is grind down the mount a half inch, but I was told by MOJO himself it should be fine as is.
Anyone else running an off center rear wheel?
You can but honestly, doesn’t mean you should. If the wheel is supposed to be off centered it would come like that from the factory. I would personally make it right.
Also, when you sit on your ruck, that wheel might be clocked at an angle.
Pictures would be helpful.
My plumb bob is sitting center…
Well I think I’m as close to center as I’m going to get.
