Doing a metruck build with 2t Zuma. Has anyone figured out how to mate Zuma harness w Honda ignition? Thanks. And glad to be back
Well… I figured it out. 2 wire swap is all you need to do. Constant power and power when turned on
Welp. Nope didn’t figure it out. Figure how to get power but it has zero spark . Put Zuma ignition back in and starts. Fml
Yes finally got it figured out. You need to hook up brown and red from Zuma harness to Honda ignition switch the there is a black and white wire you need to ground it to frame. Only problem is gotta kill switch it to turn off engine. But don’t care.
