Ended up cutting off more than that, but didn’t take a photo. Also filed it smooth.
The fender bolt hole didn’t line up with the bracket as it was slightly on the wonk. Not sure how I could have addressed this at the template stage, but with the rear panel fitted I heated the fender again, whilst in position, to try and manoeuvre it to be straight. Worked ok, but cracked some more paint.
@regenerated82 i wouldn’t say that the speedo mount model was finalised as it doesn’t quite line up with the bodywork panel, but I have moved on to other things so I’m probably not going to go back and perfect it.
Things are a bit busy over the next couple of weeks, but give me some time and I’ll go find the file and post it up.
Accuracy of Designs
As I said its not perfect. It is made specifically for my set up (e.g. riser adaptor, handlebar stem adaptor) so may need adapting to suit your own requirements (note I made my own tree riser so may not be the same height as other peoples).
I am not responsible for the accuracy, functionality, or suitability of the 3D designs. All final designs and uses must comply with applicable laws and regulations.
I cannot make any update to the model to suit your needs - this is your responsibility.
Intellectual Property
This is my design, and I own the intellectual property - I will not be held liable for intellectual property disputes. This is for use as Non-commercial, meaning you can’t sell it, but you can 3D print it for personal use.
License
Attribution-NonCommercial-ShareAlike 3.0(CC-BY-NC-SA 3.0)
This license lets others remix, tweak, and build upon my work non-commercially, as long as you credit me and license your new creations under the identical terms. More info on Creative Commons licenses
Prohibited Uses
You are responsible to check if the design violate laws, including but not limited to those that infringe copyrights, trademarks, or patents, or that facilitate illegal activities.
Quality and Material Limitations
3D printing is subject to inherent limitations in material strength, surface finish, and dimensional accuracy. You should evaluate designs / printed parts for suitability in their intended applications.
Liability Waiver
I am not liable for any damages, injuries, or losses arising from the use of the design / printed products. You assume full responsibility for the application of design / printed items.
Decided to add an LED rear light strip as I don’t think the light cluster I have is enough.
So this is attempt number 2 on the mounting bracket. Trying the get the radius and alignment to match the rear grab bar. I’ll post a picture when it’s mounted…
Accuracy of Designs
As I said its not perfect. It is made specifically for my set up so may need adapting to suit your own requirements.
License
Prohibited Uses
Liability Waiver
Light fitting and working. However I centered the mount based on the width of the LED strip. However the LED lights aren’t central - there must be a controller at the wires end.
So really I need to rotate the round part around so that the LED is central.
Great work here! Enjoyed that build thread as well! Any plans on which exhaust you are going to install? MNNTHBX just re-released their SP Exhaust and i think that would look great on here!
At the moment, I’m just leaving it on the stock exhaust. I daily my bikes and want to keep it quiet for when I leave early for work so I don’t wake my neighbours!
